2013 6L80 Transmission swap ECM Flash?
Old Feb 25, 2022 | 10:46 AM
David Masch's Avatar
Default 2013 6L80 Transmission swap ECM Flash?
I will be swapping out the transmission, as the fluid is completely burned and the torque converter shutters / slipping at low RPMs when locked up.
I hear the ECM will need to be re-flashed after the transmission is swapped.
1 - Is this a true statement?
2 - If so, what does the re-flash do?
3 - Can the truck be driven to the dealer to get flashed?
Old Feb 28, 2022 | 8:04 PM
Big_kid's Avatar
Just swap the TCM inside the transmission. You will have to pull the pan and maybe drop the valve body…
Thomas Neels
Feb 1, 2023 7:58 PM
Thomas Neels
Jan 16, 2022 2:22 PM
madaigle1
Apr 27, 2019 9:19 PM
Bigcdub
Sep 2, 2007 7:28 PM
mute_voice
Jan 8, 2007 11:58 PM
