2013 chevy silverado 1500 Rear Fuel Tank Support Crossmember
I have a bad rear fuel tank support/crossmember and wanted to purchase a new one and weld it in. I can not find anywhere that has a 2013 compatible one for sale. Does the 99-2006 fit? I would think not but I can't find anything on it. Any help would be appreciated.
im having the same problem have you found anything?
Yes, the older kit will work for this application. Replaced 3/4 of the rear cross members with the kit from Amazon in the photo- dimensions worked just fine (4th crossmember was on the front of fuel tank and under crew cab, so it wasn’t accessible)
Hope that helps
