NEW 2007-2013 Chevrolet Silverado LED Headlights | Form Lighting
The 07-13 Chevy Silverado is a great truck, both in styling and capabilities. However, the halogen lighting leaves a lot to be desired. With new headlights from Form Lighting, you can increase output and visibility, while adding modern styling and features. It’s time for an upgrade!
Click HERE to check out our 2007-2013 Chevy Silverado Projector LED Headlights!
Click HERE to check out our 2007-2013 Chevy Silverado Reflector LED Headlights!
Projector. What’s better than one projector? Three projectors. And in these headlights, all three projectors are bi-LED units, providing output for both low beam and high beam illumination. With a sharp cutoff, broad width, and high intensity, these units provide a serious upgrade in output.
Reflector. These headlights feature full LED function, including low beam and high beam. Using modern, application-specific optical reflectors, these lights produce much higher intensity and output than the factory halogen units.Modern Styling. These headlights are inspired by the late-model Silverado styling, giving your truck a much more modern appearance. This includes a C-shaped white LED running light. Even though the factory headlights don’t have a DRL, installation of this feature is simple thanks to the included wiring harness.Startup Sequence. These headlights are packed with the latest and most modern lighting functions, including a startup or “welcome” sequence. Anytime the running lights turn on, they will illuminate in a two-stage chasing sequence that is sure to turn heads, with an ultra-premium look.Sequential Turn Signal. The lower section of these headlights features a bright and highly distinctive sequential turn signal. Activating any time your turn signal is activated, the amber LEDs sequence from inside to out, with an extremely modern look.Stealth or Color Match. These lights include trim panels which go on the front of the lights. These can be left black for a stealth look, or painted to match your truck, for a custom look.OEM-Grade Construction. Form Lighting headlights are built with quality in mind, using OE-grade materials and design techniques. This includes durable UV-coated polycarbonate lenses, automotive-grade LED emitters, breather vents, and OEM plug-and-play connectors. You can rest assured that these lights will provide durable and superior performance.Road Legal. Form Lighting headlights meet all SAE, DOT, FMVSS, and CMVSS standards and regulations for legal on-road use in the United States and Canada, when installed and aimed properly - which is easy to do with the integrated screw-type adjusters.Plug-and-Play. Our headlights for the Silverado are completely plug-and play and will bolt right into place, without any gaps. They were designed to plug into your factory headlight connector, with no wiring modifications needed. No errors, flickering, or hyperflashing! If you’d like to enable the running light feature, a wire harness is included which plugs into your fuse box.Two-Year Warranty. All Form Lighting products are rigorously tested for reliability, and backed by a two-year warranty. The warranty is supported directly by Form Lighting, and any replacement parts, if needed, are shipped quickly from Form Lighting’s US warehouse. In the rare occasion that you may need to utilize your warranty, we try to keep the process as simple as possible - for example, no return is normally necessary.
Click HERE to check out our 2007-2013 Chevy Silverado Reflector LED Headlights!Do you have additional questions? We’ll be happy to help!
• Reply to this thread
• Send us a direct message
• Email: contact@formlights.com
Are you a US forum member? DM us for a FREE shipping code!
Jordan M.
Form Lighting
Jordan M.
Form Lighting
Prime Day savings are here! Ends midnight CST, 10/12/22.
NOW through 10/12, you can get 10% off at our Amazon store for Prime Day!
No coupon required.
This discount will be automatically applied.
Click HERE to visit the FORM Amazon store!
No coupon required.
Our Black Friday Sale is here, and that means it’s time to save!
Now through 11/29, you can get 15% OFF FORM Lighting storewide!
No coupon required.
This discount is automatically applied.
CLICK HERE TO SAVE AT THE FORM STORE!
LAST CHANCE for 15% off LED headlights for your Silverado! Form Lighting's Black Friday Sale ends TONIGHT!
No coupon required.
No coupon required.
ONE. MORE. SALE. 🏷
Now through 1/5, you can get 15% OFF all FORM Lighting products exclusively through Amazon and our authorized dealers.
This sale includes our new LED headlights for your 07-13 Silverado!
Shop our Amazon store ➡ Form Lighting
baddbradd (February 10th, 2023)
There’s only a few days left to save!
Through midnight 1/5, you can get 15% OFF all FORM Lighting products exclusively through Amazon and our authorized dealers.
Start your new year off right with some fresh headlights!
Shop our Amazon store ➡ https://amzn.to/3WlDQcv
Last chance everyone!
Through midnight TONIGHT, you can get 15% OFF all FORM Lighting products exclusively through Amazon and our authorized dealers.
Don’t miss out on this great chance to pick up some fresh new lights!
Check out our YouTube channel to see more!
Get Yours Here!
Get Yours Here!
