No power to cruse control on steering wheel
I have a 2009 Silverado 2500 6.0 4x4. I have checked the fuses, changed the brake switch, checked the plugs & wires. Still I do not have power to the connector behind the airbag to my cruse control switch. Any tips or guesses I'll try it!
Originally Posted by COlson
(Post 360598)
• The accelerator pedal • The brake pedal position (BPP) sensor • The body control module (BCM) • The cruise on/off switch • The + RES switch (equivalent to resume/accel switch) • The - SET switch (equivalent to set/coast switch) • The engine control module (ECM) • The throttle actuator control (TAC) motor • The vehicle speed sensor BTW, how did you determine that your C-C switch has no power? |
Test light & tried the switch on my other truck & it works
(Post 360602)
I had a spare gas pedal & checked it... Didn't help. I had PO621, PO575, PO564 codes & they all tell me about the same thing. I cleared them & they haven't came back.
