No power to cruse control on steering wheel
Old Aug 6, 2018 | 7:39 PM
COlson's Avatar
Default No power to cruse control on steering wheel
I have a 2009 Silverado 2500 6.0 4x4. I have checked the fuses, changed the brake switch, checked the plugs & wires. Still I do not have power to the connector behind the airbag to my cruse control switch. Any tips or guesses I'll try it!
Old Aug 6, 2018 | 8:29 PM
oilcanhenry's Avatar
The following are the main components of the GM cruise control system:
• The accelerator pedal
• The brake pedal position (BPP) sensor
• The body control module (BCM)
• The cruise on/off switch
• The + RES switch (equivalent to resume/accel switch)
• The - SET switch (equivalent to set/coast switch)
• The engine control module (ECM)
• The throttle actuator control (TAC) motor
• The vehicle speed sensor
BTW, how did you determine that your C-C switch has no power?
Old Aug 6, 2018 | 8:32 PM
COlson's Avatar
Test light & tried the switch on my other truck & it works
Old Aug 6, 2018 | 8:38 PM
That is good, Colson. As you can see, the cruise control sytem items that can go bad are many. In fact its a bit overdone for safety reasons, IMO. But I can see why GM made it so. Better then a multiple recall if the CC became stuck in the "ON" position.
Old Aug 6, 2018 | 8:47 PM
COlson's Avatar
I had a spare gas pedal & checked it... Didn't help. I had PO621, PO575, PO564 codes & they all tell me about the same thing. I cleared them & they haven't came back.
