Notices
Electrical Issues
Old June 18th, 2021, 9:32 AM
Misterjw's Avatar
Default Electrical Issues
Hello, I have a 2015 Silverado, recently I have experienced an issue I am unsure of how to address. The dealership said to bring it in for 2-3 days to examine so I’m looking for other options.
Periodically, while driving, the dashboard will go dark and everything shuts down except for the engine. This happens when I press the brake pedal, use the turn signal, etc. This is will happen a couple times over a few days then might not happen again for another few days. Then will happen again.
Any thoughts? My guess is there is a fuse issue or a short somewhere but don’t even know where to begin looking.
Thanks!
Old June 18th, 2021, 9:43 AM
kevinkpk's Avatar
Thanks!
Since the brake light, and turn signal are common at the turn signal switch, and your issue happens with either of them, my money is on the turn signal switch.
Old September 9th, 2021, 8:01 PM
Lduke's Avatar
I have the same issue and it occurs when the turn signals are not used. I Jaya 2016 and I’m thinking it could be a module or a ground or bare wire touching something. It’s killing me, because I really like the truck. Please help with a solution.
Old September 30th, 2021, 8:39 PM
Lduke's Avatar
I had this checked by dealer and they think that the issue is the battery and the cables linked to battery. They think the cables are corroded from within and this causes the power to fluctuate the power to this area causing the short. The estimated cost is $900 to replace battery and the cables (positive and negative). thoughts on this remedy …ALL? Please chime in
Old October 2nd, 2021, 8:13 AM
skifan1's Avatar
LD...take your battery to place that will do a load test. Go and buy a new negative cable and a new positive cable and replace them yourself. That is not a 900 dollar job! Better yet do one at a time starting with the battery and then the negative cable. Also look for bad ground cable/wires/straps/mounting points.
MJW...check grounds from your dash to frame/body.
brinson
November 2nd, 2023 12:23 PM
nancy178
October 28th, 2015 8:16 PM
Vwsinner
June 18th, 2014 9:06 PM
HelpGeorge
July 5th, 2011 11:35 AM
mxracer328
September 19th, 2010 3:36 AM
Quick Reply: Electrical Issues
