2014 Silverado 2500HD Wont start
The wife used my truck for work. After work the truck wouldnt start so had it towed home, figured it was the starter. Today changed the starter & the mega fuse 175, but now not only the truck wont start, it also says reduced engine power/ service stabilatrack. Anyone know of a solution or cause? Any help is much appreciated.
Problem solved
After taking my truck to the dealership & a diagnostic ran. The problem turned out to be a faulty ECU. Luckily my truck is still under warranty and didnt have to spend any cash.
thanks can you tell me how much it may cost also part no if possible because i m confused between ECM and PCM
also there's any chance how tell if the ECM is died
mind now i have replaced the the throttle body still some times crank some time no crank i had wait for 15 minutes then keep crank but not fired
