Shake at 35-40 and 60-70mph
Old Jan 12, 2022 | 9:37 AM
CBrault17Z71's Avatar
Default Shake at 35-40 and 60-70mph
Just found this forum still gotta do the intro part, but here it goes.
I recently purchased a 2017 Chevy Silverado 1500 LT Z71 Crew Cab 4x4 5.3l V8. It does have a 4" lift installed with 35-12.50-20 MT. Its got 120k-ish miles on it. I did have it checked over by 2 shops before I purchased it one of them I trust greatly and they specialize in off road vehicles. Both shops said it was a good truck in good shape and the lift was done properly and not by "someone with their head up their a$$". Driving the vehicle at about 35-40mph you feel a shake, and again at 60-70mph. It is a shake in the truck, not a vibration and not in the steering wheel; you feel it in the whole truck. There is no noise associated with the shake. Its always at those 2 speed brackets, goes away once you get below 30mph. I havent pushed the truck faster than 70 since the shake started so i cant say if it gets worse or better with speed.
*The rear drive shaft appears to be at the proper angle and is stiff and solid with no play or movement. There is SLIGHT play in the front drive shaft, but nothing that would cause a shake like this. The movement is marginal at most.
*I have gotten a tire balance, tire rotation, adjusted tire pressure, and got an alignment. There is no uneven tread wear
*I noticed the front driver side CV Joint was throwing grease so i just replaced the Front Driver CV Joint Assembly \
And the shake at the same speed brackets is STILL there.
All of this and i am starting to loose hope in the truck and beginning to think i got myself into a jacked up situation purchasing the truck. Any common issues or root causes to this problem, any of you experienced this and have solutions to it, any areas i need to focus on or look at next for repairs to try to fix this issue sooner rather than later.
Thank you in advance
aganguly01
Sep 1, 2021 5:34 PM
Jason Pearce
Jan 19, 2021 4:49 PM
Izzy_A
Nov 23, 2020 2:34 PM
Izzy_A
Cruze
Nov 23, 2020 1:59 PM
