2004 Astro AWD pulling hard left when braking
I have already replaced the front pads, rotors and calipers on both sides. I have read that an ABS sensor could be to blame. The right hub was replaced so the right side has a new sensor. I looked at the sensor on the left side and the housing was broken off of the sensor that inserts into the hub. Once I looked at the sensor and put it back together, the ABS dash light is now on.
Could this sensor cause the van to pull when braking? Or should I be looking elsewhere?
Alignment was checked and found to be perfect. New tires. Steering is a little loose, the tech thought a new gear box might be needed but didnt think it was that bad. Tie rods and all other components were tight.
Thanks for any help.
Grumpy did this. Replaced everything you did with no result. Went to replace the front soft lines and had the hard line it connects to on the passenger side break. Ran a new hard line in addition to the soft lines and now Grumpy stops in a nice straight line.
so I'm looking at a possible brake line issue? Makes sense.
Did you just run new lines for the problem side? Or both sides?
We had trouble bleeding the problem side (passenger). Took a really long time. But we figured it was because it was farther away.
New hard line to passenger side. New soft lines on both sides, well not new but better condition ones from my parts van.
Passenger side shouldn't take much more time to bleed, maybe a couple more pumps of the pedal.
Simon-Pierre Lacasse
February 15th, 2014 9:56 AM
ericconn
June 19th, 2012 9:56 AM
RomanGuzi
October 2nd, 2011 11:40 AM
derekf
April 24th, 2009 9:57 PM
