Astro 1985-2005
Platform: M-Body
Astro cargo van AC question
Old Apr 23, 2011 | 1:20 PM
Texvan's Avatar
Default Astro cargo van AC question
Hi all,
On my 2005 Astro cargo van, factory air, when I turn on the ac, and the fan, I can hear the fan running, but the cool air is not coming out of the vents in the dash. I can feel some cool air from different places, but not thru the vents where it is supposed to come out. I am thinking maybe a duct valve? is not opening. Is there anything I can do to remedy this? Would it be a fuse,perhaps?
Thanks,
Jim
Old Apr 23, 2011 | 8:53 PM
EinST's Avatar
I'm not sure if you're referring to a temperature setting or mode setting issue. The air temperature door takes an electric actuator whereas the other air doors take vacuum actuators. Sometimes crud builds up on an air door mechanism and the air door needs to be worked loose. Check 20A HTR-A/C fuse 12 in the I/P fuse block for the air temperature actuator?
glener
Astro
Mar 25, 2012 6:47 PM
Chevymarine
Astro
May 18, 2011 7:12 AM
Still-workin
Uplander
Apr 11, 2011 7:32 PM
oldmanchevy
Nov 5, 2010 10:37 AM
flyingmanx
Uplander
Oct 18, 2008 4:57 PM
