Humming sound
Hello all,
2003 AWD Astro Van hums very loud at all speeds, when I turn the wheel to the right just a little it goes away completely. I can keep turning the wheel all the way to the right and nothing (no vibration) but when going straight or left its there. It doesn't really vibrate but makes a loud humming sound. I changed the right wheel bearing and still no difference at all.
Thanks in advance,
Thanks in advance,
Did you check the other wheel bearing because that sounds exactly like a wheel bearing issue. Being that these bearings are like 3-400 bucks im sure you dont just want to go and change it for nothing but Ive had the same problem on 2 of my astro vans and it was wheel bearings. It wouldnt hurt checking the level in your front differential but I dont see why it would only make noise turning one way if it was that.
preppycowboy06
Dec 24, 2012 12:13 PM
