instrument lights
instrument lights
Well, since I've got the van partially dismantled, I figured it would be a good time to replace some burned out lights. Specifically the ones that illuminate the radio buttons and heat/ac controls. The right side of the dash is dark too. How do you get to them? I can't find the info in my Haynes manual. Thanks!
Steve V
Steve V
Remove the center console. Remove the screws from the upper part of the driver's knee bolster. From this point the trim around the instrument cluster/HVAC/radio is held in with spring clips. Being gentle, pull it loose. The rest should be pretty straight forward.
SteWSat
November 10th, 2007 11:46 PM
