Astro 1985-2005
Platform: M-Body
Very high rpm @ idle speed Astro 1997
Old Jun 10, 2011 | 6:46 AM
alka's Avatar
Smile Very high rpm @ idle speed Astro 1997
Y'day I drove my van about 10 Kms parked in a lot, after 2 hrs start it again, the engine roared like running @ almost 5000 rpm, got scred did not put in drive shut it off, checked all throttle cables, openedthe linkage between body and accelerator, sent to a local mechanic, checked all codes no problem seen yet.
Can some one suggest the cause.
Noticed for last few deays when I put the car in drive the rpm used to go slightly 20 5 high then roll back to normal after a minute or so.
Pl. advice any problems before I spent too much money on this old horse.
Old Jun 10, 2011 | 3:02 PM
ihatemybike's Avatar
Sounds like an idle air control.
Old Jun 10, 2011 | 10:57 PM
alka's Avatar
where it is located and how to test it also is because of vacuum leak, again how to find vacuum leak
Old Jun 10, 2011 | 11:00 PM
alka's Avatar
Smile reply to find solution
where it is located and how to test it also is because of vacuum leak, again how to find vacuum leak[/QUOTE]
Old Jun 11, 2011 | 10:07 PM
alka's Avatar
Cool idle air control valve
Did open this finally, was very dirty, checked with turning switch ON, it did move slowly back & front, not rapidly, cleaned with break cleaner , put it back , try to run the engine again, same high rpm, scred to put on drive.
Do we take it to dealer now, does not show any Codes on OBD either.
Should I replace this part cost about $132 Plus Tax, Do not mind as long it fix the problem
Let me know
Alka
Old Mar 29, 2015 | 8:08 PM
tankedbreadwinners@gmail's Avatar
Default idler pulleys' bad mon
Most likely ur idler pulley / tensionor bearing / wheel is bad or rusty which slows down the pulley set so the engine has to idle higher to keep up thus get the faulty bearing moving..... again
in2pro
Dec 25, 2020 11:34 PM
Alex_vt
Feb 20, 2012 3:01 AM
Jing
Apr 15, 2011 4:03 PM
jakeywa
Dec 11, 2010 7:18 PM
rat55chevy
May 25, 2007 3:43 AM
