2005 Avalanche 1500
I have an 05 Ava with DTC P0449, need some help on possible solutions and probable causes. Also, does anyone know if this is a recurring problem or a possible recall issue?
Thanks, Justin |
evap vent solenoid located on the cannister
the AC Delco PN 214-2082 i last heard it is 88 bucks through gm |
I had the same code last month. I bought a new gas cap and cleared the code. No issues since.
The gas tank is pressurized and when the o-ring on the gas cap wears it leaks a little causing the code. Easy $12 fix. Ken |
