2007 HELP PLEASE !! Avalanch Stabilitrak Traction Control on/off
#31
unwanted stability activation and/or a service stability message. The EBCM may have set DTC C0710. This concern may occur if the vehicle's suspension system has been modified (Lift or Lowering Kits), wheelbase length modified (limo, etc...) and/or other than stock size wheels and tires installed.
Have youmodified any of above things?
Do you get message while turning steering wheel,even if you turn few degrees?
#32
Reply on sound.
Have purchased a 2010 Avalanche LTZ only a week ago, and have noticed this annoying noise emitting from the CD/DVD/Radio/GPS in dash unit, which sounds like the laser pickup is constantly searching. It even continues after the vehicle is shut off, or if you energize any electrical device, like folding the mirrors in/out, that will trigger the searching sound again. It eventually will settle down and become quiet. However, you can still hear it as you drive. Dealer states that the factory direction is NOT to replace the radio or on board GPS unit, and that this is "normal" operation sounds. Has anybody been plagued with this annoying noise? I suspect that it could be in a Suburban or Tahoe with similar dash mounted units, as well.
I came to find out that it was my cell phone ports in the dash. I move my plug to the back and don’t have the sound anymore.
#33
THANK YOU SO MUCH. I was truly at wits end trying to figure out and narrow down what my issue could be with that dumb Stabilitrak and Traction Control lights on. You hit the nail on the head!! I had my mechanic replace the MAF and MAP Sensors. ALSO I found that the drivers side valve cover needed to be replaced with an updated version that doesn't clog the vent holes. I was told that it sounds weird but has fixed a lot of motors. This was causing blue smoke and running rough as these were the symptom's of the 5.3L engines.
Thanks to you and your post everything is running perfectly.....for now lol. Those lights may come on again with the next issue that won't pinpoint the real issue..
#34
BullDawg30
June 27th, 2022 2:05 AM
CHEVYCRZY007
April 17th, 2022 3:41 PM
knollberg
Traverse
12
May 26th, 2016 1:57 PM
KRNAYL
April 12th, 2016 3:13 PM
Deadboi77
November 3rd, 2012 12:07 AM
