Chevrolet Avalanche
Platform: GMT 805 & 900
Fiberglass Sub Enclosure for 07 Avalanche
Old March 13th, 2007 | 5:46 PM
tjmorgan's Avatar
Default Fiberglass Sub Enclosure for 07 Avalanche
Here are a couple of preliminary pics of the subwoofer enclosure being designed for the Tahoe/Suburban/Avalanche/Silverado by a friend of mine. This project has been a long time coming but will definately be worth the wait once it is finished:
As you can see, instead of just building an enclosure that mounts under the front of the center console, this enclosure will take the place of your entire inner structure of your console. The outer shell of the console will simply bolt to this inner enclosure allowing for considerably more air space and the ability to port the enclosure for a down firing 10" sub (built for the JL 10W3V3). There will be no cutting or measuring involved and the factory amp will stay in place. You will lose a slight amount of storage space in the console but as you can see from the pictures, it is still pretty big. The only thing you will have to do is remove the rear AC ducts in the vehicles with rear AC vents.
The 2 halves just need to be fiberglassed together and the enclosure needs to be tuned. I will post more pics as I get them. Anyone interested in a better sounding, higher output enclosure like this that is hidden?
TJ
SleepyTime76
June 19th, 2008 10:19 AM
earlgreer
March 30th, 2008 1:26 PM
tjmorgan
September 1st, 2007 4:30 PM
