Misfire when running above 60
I have a 04 chevy avalanche I keep getting flashing engine light when I run above 60 usually down hill misfire code p0300 I have done the spark plugs wires and coil packs. I did the cam sensor and crankshaft sensor that's when it started throwing codes. I added a couple ground wire to the tps sensor and a couple other spots which where a problem before I did the sensors. If anyone knows what the problem can be let me know. And there is no water in the gas and have good fuel pressure
iif the cats are clogged...the exhaust can't escape out the tailpipe....no air out equals no air in...the engine is a air pump. unscrewing the o2 sensors from the exhaust allows a place for the exhaust to exit.
yes 02 sensor codes will set but if the engine runs smooth and the flashing cel/ misfires are gone...you know what the problem is.
if a mechanic want to test for restricted exhaust...he/she would remove the 02 sensor and screw a pressure gauge into the hole to measure the amount of backpressure. Since you don't have a gauge...you test it by driving it.
buddyleno
March 31st, 2017 8:13 AM
Davidsednothing
December 6th, 2014 9:23 PM
chevy619
December 2nd, 2012 7:39 PM
