1988 Corsica won't start after two years sitting
Hey all, my neighbor just gave me an 88 corsica that had been sitting in his yard for two years. According to him, it ran when it was parked and was driven there. So I charged up the battery and though it turns over, it won't fire up. Just wondering where to start. Thanks
check for:
spark, use a proper spark tester fuel, is there fuel at the fuel pressure Schrader valve. compression with a compression tester |
Originally Posted by tech2
(Post 253661)
check for:
the fuel pump should run for 2 seconds when the key is turned to run
Checked earlier and I'm getting no fuel at the rail. Fuel pump fuse is good, new relay came with car and it put it on. Still no fuel at the rail.
if your not hearing the fuel pump run for 2 seconds at key on; check for power and grd at the fuel pump harness connector. If you have battery voltage for that 2second prime, and the grd is good, replace the fuel pump and fuel filter.
If you want to see if it will start, spray at 2second blast of brake cleaner in the air cleaner snorkel. if it fires up on brake clean, you know it a fuel delivery problem. |
(Post 253760)
Originally Posted by mdisco77
(Post 253768)
Will try.
the fuel pump harness will be connected at the top of the tank. It may not be accessible without lowering the tank.
(Post 253833)
