Beretta, Corsica, & pre-1995 Lumina Among this grouping, these three cars, while being similar to each other, offered something for everyone, from a sports coupe to a roomy sedan.
Platform: L-Body
1988 Corsica won't start after two years sitting
Old Aug 1, 2013 | 6:03 PM
mdisco77's Avatar
Default 1988 Corsica won't start after two years sitting
Hey all, my neighbor just gave me an 88 corsica that had been sitting in his yard for two years. According to him, it ran when it was parked and was driven there. So I charged up the battery and though it turns over, it won't fire up. Just wondering where to start. Thanks
Old Aug 1, 2013 | 7:37 PM
check for:
spark, use a proper spark tester
fuel, is there fuel at the fuel pressure Schrader valve.
compression with a compression tester
Old Aug 1, 2013 | 10:05 PM
mdisco77's Avatar
Originally Posted by tech2
check for:
I have a a spark tester so I can do that. There should be fuel pressure as soon as the key is on right? I can check tomorrow.
Old Aug 2, 2013 | 7:08 PM
the fuel pump should run for 2 seconds when the key is turned to run
Old Aug 3, 2013 | 12:16 AM
mdisco77's Avatar
Checked earlier and I'm getting no fuel at the rail. Fuel pump fuse is good, new relay came with car and it put it on. Still no fuel at the rail.
Old Aug 3, 2013 | 10:02 AM
if your not hearing the fuel pump run for 2 seconds at key on; check for power and grd at the fuel pump harness connector. If you have battery voltage for that 2second prime, and the grd is good, replace the fuel pump and fuel filter.
If you want to see if it will start, spray at 2second blast of brake cleaner in the air cleaner snorkel. if it fires up on brake clean, you know it a fuel delivery problem.
Old Aug 3, 2013 | 12:27 PM
mdisco77's Avatar
Will try.
Old Aug 4, 2013 | 12:18 AM
mdisco77's Avatar
Originally Posted by mdisco77
Will try.
I tried connecting 12 volts to the test lead and still no noise from pump. Where is the harness connector you're talking about? By the gas tank?
Old Aug 4, 2013 | 11:29 AM
the fuel pump harness will be connected at the top of the tank. It may not be accessible without lowering the tank.
Old Aug 4, 2013 | 11:31 AM
mdisco77's Avatar
Okay. Looks like this is going to go on the lift one way or another. I'll try to take the tank out.
