Beretta, Corsica, & pre-1995 Lumina Among this grouping, these three cars, while being similar to each other, offered something for everyone, from a sports coupe to a roomy sedan.
Platform: L-Body
90 Beretta starts and stalls after 2 sec
Old April 19th, 2010 | 11:17 PM
bigheadfred's Avatar
Default 90 Beretta starts and stalls after 2 sec
1990 Berretta 2.2 starts, but shuts off right away. It will do this repeatedly. The injector sprays briefly and stops. It will keep running if starting fluid is sprayed in the throttle body. I replaced the fuel pump and the crank sensor. A test light shows the injector has a pulse. The fuel pump pressure is about 40#.
Any ideas why it won't stay running.
Smart men solve problems, wise men avoid them!
Old April 19th, 2010 | 11:24 PM
maxxman04's Avatar
fuel pump relay
Old April 19th, 2010 | 11:27 PM
I forgot to mention that i swapped the fuel pump relay with the one beside it and had the same results. So, I think the relay is ok.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Old April 19th, 2010 | 11:38 PM
maxxman04's Avatar
fuses?
Old April 19th, 2010 | 11:49 PM
I chcked all fuses, and all were ok. Even the 20 amp on on the firewall.
Old April 20th, 2010 | 12:11 AM
maxxman04's Avatar
has the oil pressure gauge quit working? the ignition and fuel system are tied into the oil pressure sending unit. this is a fail safe in case engine should lose oil pressure, it cuts the fuel delivery so further engine damage does not occur. low oil level, bad sending unit, messed up wires could cause the fuel to shut off after the 2 second relay.
Old April 20th, 2010 | 12:22 AM
Maxxman
I think you may have something with the oil presure. I was setting here earlier thinking , and remembered reading in the fuel pump instructions that if the oil presure sensor isn't working the fuel pump will not work. I forgot about reading that little foot note. I will check out the oil presure tomorrow, and hopefully that will solve the problem. I guessing I can spray the throttle body with starting fluid and watch the oil presure gauge to see if it has a reading.
Any testing ideas are greatly welcome!!
Thanks for your help
Old April 20th, 2010 | 10:25 PM
Well the oil sending unit didn't solve the problem. Trying to figure what to do next we made the fuel pump run continually. That focre gas all the way to the injector, but it made no difference. It still shut down after 2 sec. The injector is pulsing only once then it dies. Could the injector be bad or is something else making it shut down?
help
Old April 25th, 2010 | 8:51 PM
I finally figured out what the problem was. We hot wired the fuel pump so it couldn't shut down, and still had the same issue. So everything was working fuel, pulse, but stillit wouldn't stay running. So. that said to us it was the injector that was failing. It was only giving one squart of fuel and stopping. I got an injector from a scarp yard and that fixed the problem.
Thank you maxxman04 for your help!
CZ0
November 16th, 2011 7:28 AM
arabian49
October 14th, 2009 9:55 PM
TheHunterofShadows
October 18th, 2007 12:44 PM
tsi18psi
September 19th, 2007 5:39 PM
Quick Reply: 90 Beretta starts and stalls after 2 sec
