Bolt EV New Chevrolet Bolt forum to discuss GM's budget Bolt EV with 200+ mile electric range!
Chevrolet Bolt
Pads and rotors @ 27k
Old Jun 18, 2021 | 10:10 PM
Tetramer's Avatar
Default Pads and rotors @ 27k
My dealer informed me I need new pads (2-3mm) and rotors (grooved and corroded) for front and back of my Bolt. The car is less than 3 years old and has only 27k miles. I don't debate the need, but something isn't right. At my first inspection with 9k miles the dealer told me the rotors were corroded and I wouldn't pass inspection. They machined them (their words) so they would pass. At that time, I asked why they wouldn't replace the rotors and was told it is GM policy to machine first. I think they should have given me new rotors at that time, but I lost there. By machining them, they removed any existing anti-corrosion coating (which wasn't working). The dealer isn't budging and GM Customer Care deferred to the dealer since it is "wear and tear". I think an EV should go well over 50k miles....my Prius made it 75k it was only a hybrid with minimal regeneration. Has anyone seen this in their Bolt or have advice? I am very disappointed in Chevy right now.
Old Jun 18, 2021 | 10:56 PM
there is no anti corrosion coating. the ability to stop corrosion is a rotor is all about its metallurgy. Machining won't change a rotors ability to stop corrosion.
Another factor for rotor corrosion is environmental conditions; do you live in the rust belt? If you do; you need to service ie clean and lubricate the caliper pins and brackets yearly....if not, accelerated wear, irregular pad wear and bad rotor finish/corrosion will occur.
It is gm policy to machine vs replace as long as the rotor is not under min spec thickness or damaged. That is a battle you will never win. Gm will pay for one brake repair under warranty as it is consumable parts.
maybe toyota uses better metal.
Old Jun 19, 2021 | 10:14 AM
Tetramer's Avatar
The Volt came with FNC coated rotors. I assumed the Bolt does too. Coated rotors do exist as OEM ACDelco. Why would you say coatings don’t exist and machining wouldn’t remove the coating?
Old Jun 19, 2021 | 10:51 AM
not familiar with fmc. the only coating i have seen is the grey coating on gm rotors that is burned off during brake burnishing.
i goggled fmc. if you read the actual process the coating is 10 microns the width of a human hair.. the purpose is to stop lot rot....rust from lack of use...sitting on a dealer lot. A surface finish that thin won't last. a rotor has 60 thousand of an inch of working thickness btw. if your surface finish was bad...the coating was gone.
Flyfishtrip
Feb 24, 2014 7:31 PM
WalterS
11
Sep 5, 2012 8:53 PM
wiktor
Oct 3, 2010 9:16 AM
astarfunkwaent
May 1, 2009 5:49 PM
timmyjimmy5150
Dec 10, 2008 7:47 AM
