1995 Camaro window issues
Hello,
im new to these forums so forgive me if this is a repeat? but i couldnt find anything in the search function. Anyways here goes
My power windows work when they want too the driver side goes down ok but up it takes a bit of trying and the passenger side wont go back up yet... it could be a day or two then it might work? any ideas or help would be great thank you for your time!
Stephen
Stephen
Senior Site Administrator
Time to replace the window motor...its a very common issue on these cars. Any local parts place should be able to get you one. Keep in mind the original one is riveted in so you will have to drill it out and install the new one with bolts and nuts
You can go cars rock. Com and buy one like me, it was like less than forty dollars new. Google how to replace a window motor camaro in a quarter and you should find a step by step with photos! This helps a lot. Its relatively simple process when you have 4 times lol.
davbell22602
March 10th, 2010 8:36 PM
