89 CAMARO 305 V8 STICK OXC
89 camaro 305 v8 stick shift anyone out there that knows about these rides. i got this ride from a homie thats locked up state. so i put in a new starter and new alternator new cables new steering colum . its got something like msg disturberator cap and coil its red i got timming one . i still have thisone problem.when im driving it and it reaches warm temp. on second gear it shuts down then it backfires so i put it in nutral and just push o te accelorator pedal and starts up .when its warmed up and in PARK AND IPUMP THE GAS PEDAL IT DIES OUT.
RE: 89 CAMARO 305 V8 STICK OXC
Its kind of hard to diagnose a car over the internet, but I'll see what I can do. Is it carbureted, throtle body, or tune port? I had a camaro with similar problems, when I would press on the gas quickly the engine would die but if I pressed on it slowly it wouldn't die. I found out it was the EGR valve and it took care of that problem. Did the car come stock with the manual tranny?
ccnchevroletforum
June 20th, 2012 8:17 AM
grmstrj
July 6th, 2007 9:17 AM
