BBC help
Hi everyone I'm Freddie new to the forum I've been searching all over the web trying to see if what I have will work in my 79 Camaro I have a gen v block casting numbers 10114182 I also have a set of closed chamber heads casting numbers 3964290 I've seen where I would need special head gaskets to make this work then I've seen post saying this won't work at all just looking for a straight answer and what would need to be done to get this to work if it's possible |
Originally Posted by Freddie Finley
(Post 368515)
(Post 368558)
I'd take a look at the fel-pro website for the proper gaskets.Cant say for sure what will work since the 79 had open chambered, low-compression heads.
