2016 Camaro
Platform: F-Body & Zeta.
Camaro won’t start!
Old Jan 17, 2005 | 1:56 PM
hannah's Avatar
Default Camaro won’t start!
I have a 3.1 V6 camaro, 1992 RS.
I have recently replaced the starter motor, then the battery. For some reason now, it will not start. What have i done? Can anybody help? Obviously, being in the UK is not helpful with issues like this so any help will be gratefully recieved...
All the best,
Hannah
Old May 17, 2005 | 5:41 AM
burntcha@netzer's Avatar
<FONT face="Verdana, Arial, Helvetica, sans-serif">DID YOU TRY THE ELECTRONIC IGNITION MODULE UNDER THE DISTRIBUTOR CAP ? BET THATS IT BEEN THROUGH THE SAME THING.</FONT></P>
<IMG src=smileys/smiley1.gif border="0">KRISPY BURNTCHA</P>
Old Oct 14, 2005 | 2:13 AM
rick 34's Avatar
</P>
<FONT color=#ff0000>.</FONT> Take a look at the ignition key. There should be a pellet on it. This is known as the VATS pellet. It's a anti-theft part. The ignition cylinders have very fine wires running down the column that break with the turning of the key. If one opens while you go to start, the PCM will look at this as an unauthorized start and shut down the starter and fuel. A dealer has a tool that hooks into column wires to check that this pellet is sending it's resistance value to the PCM. This is not to difficult IF you have the tools to take column apart. But if you have an airbag, better let them do it. There is an outside chance that the key is worn out as well. If you have a spare, try it first.<!---
<CENTER>
</CENTER></P>---></P>
excesss
Feb 22, 2006 9:15 PM
beaverton007
Nov 14, 2005 11:20 PM
yellowsnow
Camaro
Sep 1, 2005 12:18 AM
yellowsnow
Camaro
Sep 1, 2005 12:14 AM
