2016 Camaro
Platform: F-Body & Zeta.
can't get started....need help
Old Dec 27, 2005 | 9:58 PM
838992chevy's Avatar
Default can't get started....need help
I have a 89 camaro with a little work done to it The problem is the fuel system. I bought it a couple weeks ago and the pump went bad, so I changed it out and now I can't get it started. When the pump is on, it sound like there is air in the fuel rails...like a hissing sound. I tried to bleed any possible air out, but all I got was fuel. When I try to start it, it will act like it doesn't have enough fuel to get moving. I've tried everything I can think of. Anyone have any ideas on this?
Old Jun 12, 2007 | 10:29 AM
mechanixnew's Avatar
Default RE: can't get started....need help
you need to check and see if you are getting too much fuel, it will do the same as not enough.
desert_chris
11
Jul 14, 2025 8:39 PM
kah6987
15
Jan 21, 2013 11:51 PM
KentuckyTroy
Sep 26, 2011 9:17 PM
98Silverado1500
Mar 3, 2009 11:34 PM
