chrisdios02 |
May 7th, 2021 10:43 PM |
Fog Light Issue with my 2013 Camaro
So I noticed a fog light bulb was out on my camaro and since I figured it needed replacement I would do so with LED bulbs. I changed the bulbs changed, but when I go to turn the fog lights on only the passenger side fog light turns on, and the driver side fog light does not. I thought maybe it was a bad connector and I was planning on changing it but when I locked the car with the key fob both fog lights turned on. They do the same when I unlock it so I don’t think the connector is bad and I also don’t think it’s the fuse if one fog light works. Any ideas? Don’t know if this has happened to anyone. Could used some tips. Thanks!
