2016 Camaro
Platform: F-Body & Zeta.
Fog Light Issue with my 2013 Camaro
Old May 7, 2021 | 10:43 PM
chrisdios02's Avatar
Default Fog Light Issue with my 2013 Camaro
So I noticed a fog light bulb was out on my camaro and since I figured it needed replacement I would do so with LED bulbs. I changed the bulbs changed, but when I go to turn the fog lights on only the passenger side fog light turns on, and the driver side fog light does not. I thought maybe it was a bad connector and I was planning on changing it but when I locked the car with the key fob both fog lights turned on. They do the same when I unlock it so I don’t think the connector is bad and I also don’t think it’s the fuse if one fog light works. Any ideas? Don’t know if this has happened to anyone. Could used some tips. Thanks!
Old May 8, 2021 | 6:49 PM
was the steering straight when you checked the lamps. some new models will shut down the corresponding lamp when the w heel is turned to that side.
Old May 26, 2021 | 9:57 PM
chevyboy@22's Avatar
Any work done to front facia or harness? Bent a pin when reconnecting my wiring harness to front fascia and fogs wouldn't work. Removed harness, straightened pin and fixed the issue.
Old Aug 13, 2021 | 10:13 PM
Is it a blown fuse? that could be the factor
gmlover
Aug 3, 2015 12:19 PM
BMoTahoe
Mar 15, 2012 9:29 PM
02Z71silverado
Dec 28, 2008 8:41 PM
steeler560
Nov 19, 2007 12:13 AM
