No power to fuel pump
I have a 1990 Camaro RS. I used a light tester and it has a gray wire (no power), purple wire (slight light) and a black wire (ground?) going to the fuel pump. I decided to run a jumper wire that is hot when the ignition is turned on and connected it to the gray wire leading to the fuel pump and now the fuel pump will run. I get gas all the way to the throttle body, but the injectors will not spray. I replaced the injectors and ignition module under the distributor and even switched out the computer.. still nothing.
If anyone has any kind of insight into this problem, please, fill me in...
mangomanj
August 17th, 2014 9:51 PM
22charlie
March 21st, 2013 9:54 AM
BRB
December 28th, 2012 8:34 PM
hunter10220
May 18th, 2011 8:37 PM
ross_boss08
August 4th, 2008 2:41 PM
