Platform: B-Body
Failed Inspection-Need Some Help
Old Apr 25, 2010 | 1:24 PM
1stCaprice's Avatar
Default Failed Inspection-Need Some Help
My wife took her '05 G6 in today to get inspected and it failed. Both outer tierods are shot and so is the lower ball-joint on the passenger side. I'm assuming the outer tierods are as easy to replace as any other car, unscrew them and screw the new ones back on? I'm not finding anything that says you can just replace the balljoint, but you need to replace the whole lower control arm.....is this correct? If so, is replacing the control arm easy enough with normal hand tools?
Any help is appreciated.
Thanks
Adam
Old May 31, 2010 | 2:26 AM
IndyL03's Avatar
should be easy as hell cept for might have to loosen axle nut. but pretty simple especially if you have air tools.
wrstllanc
Sep 2, 2015 1:11 AM
Chevymanster
Avalanche
Feb 12, 2010 11:37 PM
Sturmvogel
Aug 20, 2008 10:32 AM
cobalt07
Cobalt
Jul 2, 2008 9:01 PM
tampc
Oct 26, 2007 6:34 PM
