04 2.2 grounding wire after tranny swap sparking
I just swapped the auto tranny on an 04 2.2. I believe I hooked up everything correctly except the grounds. There is a red one from the positve battery terminal a black cnnected to the negative battery termnal from the battery to the battery pan and then agan from there to the tranny? There are also two connected to the wiring harness one that runs along the inside of the battery and one from in the front close to the fan. I thought I put them back the way they came of but now if I try to connect the battery it sparks like crazy. And ideas would be great or links to pics of how it shold go. Thanks in advance for the help.
darkroom1428
May 16th, 2011 8:48 PM
