05 cavalier help
05 cavalier help
I recently got a used 2005 Chevy Cavalier with around 87000 miles on it. I took it to the shop and they said everything checked out fine except for an oil leak that i got fixed since then it has been running perfectly but, on my way home from work I was listening to the radio and I went over some train tracks and the radio turned off the didgital clock turned off and the speakers made some weird noises then stopped and I haven't been able to turn on the radio or the clock. The whole entire computer isnt broken because the AC works fine. If you have any ideas about something I could do to fix this problem please help. Thanks.
Always check for blown fuses first. Next check the plug going into the back of the radio and the ground to the radio. Something appears to be loose or disconnected.
Toddbrandon28
September 26th, 2014 7:26 AM
atomheartmother
June 29th, 2008 9:41 AM
