2002 Chevy Cavalier No Start No Crank
i Have A 2002 Chevy Cavalier That Suddenly Stopped While I Was Driving & Won’t Start Back Up . Any Suggestions? |
Originally Posted by Mariahg1
(Post 369726)
Did It Make Any Noise When You Turned The Key ? Mine Isn’t But doing anything But The Lights And Radio come On |
(Post 369737)
Try this. Remove the hose from the airbox to the intake. Spray a liberal amount of starting fluid in the intake. Try starting. If it runs for a second or stumbles, then you are getting spark and it is a fuel issue (fuel pump failure).
the car would still crank over with a bad fuel pump so you can rule out anything fuel related.
-make sure the battery is good. fully charged it should be 12.6volts...the headlights should come on bright. If its in question...many auto parts stores will test it for free. -if the fault is still there once the battery is rule out: -find the underhood fuse box. find the starter relay....have someone turn the key to crank/start...the relay should click...report back with your findings. |
(Post 369726)
i Have A 2002 Chevy Cavalier That Suddenly Stopped While I Was Driving & Won’t Start Back Up . Any Suggestions? If you are looking for the best battery tender for your car you can find here A no-crank situation suggests that your problem is battery or starter related? Is your battery charged? As said, you should have >12V. What happens when you turn the ignition on? Does your dashboard illuminate? What happens when you turn the key to a engine start position? Does your dashboard stay illuminated, or it dims? If your windows, radio or headlights don't work, you probably have a dead battery. Hope this helps! |
