Platform: J-body
2002 Chevy Cavalier No Start No Crank
Old Jan 25, 2019 | 10:40 AM
Mariahg1's Avatar
Default 2002 Chevy Cavalier No Start No Crank
i Have A 2002 Chevy Cavalier That Suddenly Stopped While I Was Driving & Won’t Start Back Up . Any Suggestions?
Old Jan 25, 2019 | 1:07 PM
oilcanhenry's Avatar
Fuel pump bit the dust. Had it happen to me on my old cavalier.
Old Jan 25, 2019 | 1:30 PM
Mariahg1's Avatar
Did It Make Any Noise When You Turned The Key ? Mine Isn’t But doing anything But The Lights And Radio come On
Old Jan 25, 2019 | 2:03 PM
When my pump went out, I had no indication before hand that it was going to I was driving, then it just died.
Old Jan 25, 2019 | 8:07 PM
Doug D's Avatar
Try this. Remove the hose from the airbox to the intake. Spray a liberal amount of starting fluid in the intake. Try starting. If it runs for a second or stumbles, then you are getting spark and it is a fuel issue (fuel pump failure).
Old Jan 26, 2019 | 12:01 PM
the car would still crank over with a bad fuel pump so you can rule out anything fuel related.
-make sure the battery is good. fully charged it should be 12.6volts...the headlights should come on bright. If its in question...many auto parts stores will test it for free.
-if the fault is still there once the battery is rule out:
-find the underhood fuse box. find the starter relay....have someone turn the key to crank/start...the relay should click...report back with your findings.
Old Jan 30, 2019 | 2:08 AM
mikeross1209's Avatar
If you are looking for the best battery tender for your car you can find here
Hi!
A no-crank situation suggests that your problem is battery or starter related?
Is your battery charged? As said, you should have >12V.
What happens when you turn the ignition on? Does your dashboard illuminate?
What happens when you turn the key to a engine start position? Does your dashboard stay illuminated, or it dims?
If your windows, radio or headlights don't work, you probably have a dead battery.
Hope this helps!
