Platform: J-body
2004 Chevy Cavalier wrong spark plug gap
Old Nov 14, 2012 | 5:35 PM
  #11
Originally Posted by Mike San
How do I know if it happends after the engine gets hot? the MIL light is present all the time. I have change to premium fuel to see if helps but it doesn't
when its misfiring the engine will exhibit a shake which you can see with the hood open. there will be a lack of power when driving.
misfire monitors run continuously and will set the SES light on immediatly. clear the code. start it up cold and drive it unitil the misfire occurs and note the conditions.
engine hot or cold
at idle or under load
intermitantly or all the time
Old Nov 15, 2012 | 7:42 AM
  #12
Mike San's Avatar
This is the picture of the coil pack, I am not sure if I can try the screw driver test, I am afraid can blow the module. I will do what Tech2 is recommending, will clear the DTC and drive it to find out when is on again, will report back after the tryout. I know that this kind of vehicles clears the code after 3 cycles of code not being present so I am sure what I have done has'nt worked.
I did clean the injectors with an AC Delco additive.
I am reluctant to change the coil, I am not sure it will fix the issue.
Old Nov 15, 2012 | 8:56 PM
  #13
the coils or module are the most likely cause.
the injectors are pretty reliable on these cars.
how are you clearing the code?
Old Nov 17, 2012 | 6:41 AM
  #14
Mike San's Avatar
I will go to one of these part shops, I believe they can help me to clean the codes
Old Nov 21, 2012 | 9:13 AM
  #15
Mike San's Avatar
Default Misfire occurs on cold start
engine hot or cold
I finally was able to do the tryout, the misfire occured on cold start. I cleared the code when vehicle was hot and did not came up until the early start up @ idle
Old Nov 26, 2012 | 9:14 AM
  #16
Mike San's Avatar
I changed the coil and module, the SES light still on, but not sure if is a different code, the car feels with more power, so I guess there was a wrong coil. I will scan the vehicle again.
Old Dec 10, 2012 | 8:12 AM
  #17
Mike San's Avatar
Default Coil fixed the DTC P0303
The coil fixed the issue, but now I have a new DTC P0171, will check for vacum leaks.
cbennett51@cox.net
Feb 11, 2011 12:10 AM
Natidonkryda
Jul 29, 2008 3:52 AM
03trackit
May 12, 2008 4:08 PM
03trackit
May 12, 2008 1:07 AM
