95 cavalier 2.2L 5speed wont start
![Angry](https://chevroletforum.com/forum/images/icons/icon8.gif)
Ok I've been working on this car for a few weeks now and can’t fix it. It started with a dead batt I jumped it and tried to go to work had lots of problems driving then it died again before I got to work. Had it towed home where I look at the batt again and saw that it now cracked. So i got a new batt tried starting my car and the batt died again so I looked at the alternator and found its electrical connection had broken. So I picked up a new alt with a new belt put it all in and the car still will not start. What happens when I try to start it is one of two things one it will crank at a good speed for about 1-2 tries (that’s 3 cycles a try totaling 6 at best) then the new batt is drained. Or it will crank fire once or twice at best very very hard then die out again. I do not know what to look at I can hear the fuel pump priming I can guess there’s spark if its firing every now and then. IDK what could be wrong MAP, IAC, TPS, CKP sensor maybe a short in the wiring?![Confused](https://chevroletforum.com/forum/images/smilies/confused.gif)
THKS for any help.
THKS for any help.
Chevys10tahoe
May 6th, 2013 10:32 AM
Chevyguy1987
June 7th, 2011 7:01 PM
95silverado
November 25th, 2010 6:46 PM
mrlant
November 11th, 2007 7:16 PM
