Platform: J-body
battery light
Old Apr 1, 2010 | 6:30 PM
amberghini's Avatar
Default battery light
About a week ago my battery died, so i bought a new one, which died shortly after. Assuming then that the issue was my alternator i had the alternator fixed. But still after all this my battery light refuses to go off. So I took the battery to get tested and it was fine. Anyone have any ideas about what might be the problem?
Old Apr 1, 2010 | 8:35 PM
MDTAHOE's Avatar
Professional Mechanic
Have the new Alternator checked.
Old Apr 1, 2010 | 10:57 PM
amberghini's Avatar
the guys who fixed the alternator checked it after they fixed it and it was putting off power.
Old Apr 5, 2010 | 3:47 AM
Roanoker494's Avatar
Battery light is usually controlled by wire connected to the alternator. With the car off use a volt meter to check the battery voltage, a good battery will actually read around 12.7 volts. Do the same test with the car running and all the power options, like headlights and defroster, turn on. You should find a high reading than when the car was off. Could be a open circuit for the battery light, meaning a bad wire or loose ground strap. I have seen the electrical connector on a alternator "burn out", might want to pull that plug off and check it closely. Most auto parts store store replacement connectors if that turns out to be the problem. Hope this info helps in some way.
Old Apr 16, 2010 | 12:41 AM
jsmthjsmith83's Avatar
I think it's possible due to not charging properly or you've got a short somewhere,you Have to check alternator tested,If it's not the alt, my guess would be to inspect the usual suspects,it is also possible due to battery totally discharge,you can check light bulb-holders (look inside at the terminals),door switches,ignition switch, the solenoid contact on your starter.
Old Apr 17, 2010 | 12:23 AM
amberghini's Avatar
It turned out to be the alternator. They people who "fixed" it apparently didn't really fix it, and also neglected to tell me it had been repaired once before by the previous owner. I bought a refurbished one, and it's working just fine now.
Thanks for everyone's help!
kllawson
Avalanche
Dec 22, 2010 6:31 AM
Igotasilveradonstuff
Dec 8, 2010 12:55 PM
Sirius018
Jul 17, 2010 10:10 AM
Deteoni
Mar 28, 2009 1:39 PM
rwrows
Apr 6, 2008 12:04 PM
