Cav. Master Cyl. Question
ok guys...i might be changing the master cyl. on my friends 96 Cav. with ABS... i looked at it and the ABS is connected directly to the master cyl. Do I just disconnect the brake lines, then the electrical wiring, and then the 2 bolts on the master cyl.? or is there a way to just take off the ABS off the Master cyl.? or is it all one piece? also... she told me that she has hardly any front brakes at all... she said the pads need replacing and i'm going to do that...but what else could it be? i'm gonna bleed the brakes and see if that works... but could there be anything else that would cause the front brakes to just semi stop?
her Cav. as 90k on it
philgethifi
16
May 27, 2009 11:52 PM
