Engine wiring harness questions
I have a 2.2 L with a bad harness, but everywhere near me has had issues with people chopping the wiring harnesses when removing ECU, and as a last stitch effort to get things running my friend asked if I could use his wiring harness from his 96/97 s10 that originally had a 2.2L... is this possible without major modification?
Not sure why, but every junkyard around me is in the same boat, when someone removed the ECUs, they just cut it out instead of unplugging it...
Many years ago, before the pro-pickers, I put an entire A/C system into a vehicle with no A/C. I could not possibly do that these days.
If there is nothing else wrong with a junk yard wiring harness except for the plug at the ECU, you can splice in your old plug and make a good harness. That is if you have the plug. I haven't checked, but you may be able to buy the plug. Check Ebay you xcan find many odd parts for sale there.
