Platform: J-body
Help! Fuel leaking at engine
Old Mar 13, 2018 | 3:12 AM
ohyeah96's Avatar
Default Help! Fuel leaking at engine
I have a 1996 2.2 leaking fuel onto the intake runners. Seems to be coming from around the top of #1, 2 injectors. Installed new oring set to injectors, replaced regulator and fuel return line seals and still have leak. Only when it's running and doesn't drip but covers a good 3inch space on intake back from injectors. Is something cracked or not seating right, common issue? I can't find anything else on this. All help appreciated as this is my a-to-b car. Thanks.
Old Mar 13, 2018 | 8:06 AM
is the fuel leaking out throught the electrical connector part of the injector?
