Platform: J-body
Old Jul 22, 2015, 10:50 AM
How-Tos on this Topic
Last edit by: IB Advertising
Print Wikipost
How-To: Replace the Radiator on a '01 Cavalier
Old Oct 11, 2011 | 1:03 PM
MyBowTieGuy's Avatar
Default How-To: Replace the Radiator on a '01 Cavalier
Hello everyone,
Here is a succinct and straight-forward guide to replacing the radiator on a '01 Cavalier:
1) Disable the SIR system.
2) Drain the cooling system.
3) Remove the hood latch.
4) Remove the right and left headlamp assemblies.
5) Remove the radiator upper mounting bolts and the upper radiator mounts.
6) Raise the vehicle.
7) Disconnect the forward discriminating sensor harness.
8) Remove the cooling fan assembly.
9) Use the special tool J38185 in order to reposition the radiator outlet hose clamp from the radiator.
10) Remove the radiator outlet hose from the radiator.
11) Remove the lower transmission oil cooler line from the radiator.
12) Lower the vehicle.
13) Remove the hood latch support bracket and the forward discriminating sensor with the harness.
14) Remove the upper transmission oil cooler line from the radiator.
15) Use the special tool J38185 in order to reposition the radiator inlet hose clamp from the radiator.
16) Remove radiator inlet hose from radiator.
17) Remove the surge tank inlet hose and the clamp from the radiator.
18) Remove condenser to radiator mounting bolts.
19) Remove the condenser from the radiator, if equipped. The radiator can be removed without discharging the A/C System.
20) Remove the radiator assembly from the vehicle.
-Installation-
1) Install the radiator assembly to the vehicle.
2) Install the condenser to the radiator.
3) Install condenser to radiator mounting bolts.
4) Use the special tool J38185 in order to install the surge tank hose to the radiator.
5) Route the forward discriminating sensor harness.
7) Install the lower transmission oil cooler line to the radiator and tighten the line to 27 ft. lbs. (36 Nm).
8) Install the cooling fan assembly.
9) Install the radiator outlet hose to the radiator.
10) Use the special tool J38185 in order to reposition the radiator outlet hose clamp.
11) Connect the forward discriminating sensor harness connector.
12) Lower the vehicle. install the radiator inlet hose to the radiator.
13) Use the special tool J38185 in order to reposition the radiator inlet hose clamp.
14) Install the upper transmission oil cooler line to the radiator and tighten the upper transmission oil cooler line to 27 ft. lbs. (36 Nm).
15) Install the upper radiator mount bolts to the upper tie bar and tighten the bolts to 89 lb inches (10 Nm).
16) Install the hood latch support.
17) Install the right and the left headlamp assemblies.
18) Install and adjust the hood latch assembly.
19) Fill the cooling system.
20) Enable the SIR system.
*diagram courtesy of gmpartsgiant.com; all rights reserved
Old Oct 6, 2017 | 8:53 PM
MHaner's Avatar
Question Replace Radiator in 2003?
Is it the same as 2001? How do you get the radiator past the AC condenser and tubing? What mounting bolts disconnect the condenser from the radiator? If I can lift it out the radiator bracket is that " disconnected "?
Because it loose and unhooked from every thing but will not fit out., it is too wide where the hose attaches.
xxCountryBoyxx
Dec 18, 2013 7:18 AM
JWR4
Mar 11, 2012 4:38 AM
jr1017
Nov 5, 2006 6:16 PM
dieselkid
Oct 11, 2006 3:41 PM
generaldavis
Aug 17, 2006 7:41 PM
