need help with my caviler
i have a 2004 2.2 caviler problem. i drove home from work parked and when i went to start my car in the am it will only crank but not start. i have changed fuel pump , starter , spark plugs and all. i do get a spark but i dont know what else to do
how did you confirm spark? the ignition modules are notorious for failing.
if you spray a 2 second shot of brake cleaner into the throttle; does it start briefly?
what did the old spark plugs look like?...flooded/wet?
