Platform: J-body
Need Some Quick Basic Info
Old Jan 28, 2013 | 2:39 PM
tragichip's Avatar
Default Need Some Quick Basic Info
I have a 98 cavalier Z24. My clutch pedal over the past few years will suddenly go soft and fairly low to the floor somedays. After usually a week or so it stiffens up and is like brand new, and will stay like this for months on end. I was going to rule out a leaking slave cylinder but the thing that catches me is where it is leaking. Typically i bealieved that if it was a slave it would be dripping from the bell housing. Which is the one with the bleeder on the top right side of what i believe is the bell housing. It is leaking off of where the drivers side CV goes into the tranny. This makes me think maybe a lose hose or possibly the master cylinder? Any help would be greatly appreciated
Old Jan 28, 2013 | 3:44 PM
Clean everything up real good and then watch closely to see where it is coming from. You already named all the possibilities.
Old Jan 31, 2013 | 5:15 PM
tragichip's Avatar
So I took another brief look at it and it actually doesnt seem to be leaking at all, I have been checking the clutch fluid everytime after driving and no level change so I am starting to wonder maybe i should just bleed the lines or change the fluid entirly. It is very black and I read that meant the fluid caught moisture. One more thing is when i drive it for like say a half hour or so the pedal returns to normal position. What do you think?
Old Jan 31, 2013 | 5:17 PM
tragichip's Avatar
And this problems only seems to happen when its cold. I live in Canada and this all started last week when it hit -25
Old Jan 31, 2013 | 8:31 PM
Segfault's Avatar
Master. No leak anywhere, happens in cold. I'd rebuild the master.
Old Feb 2, 2013 | 5:44 PM
tragichip's Avatar
So before I tried the master or slave I thought I would flush old black fluid and put new fluid in and now I cannot get any pressure to the clutch. First time opening the bleeder was fine lots of fluid and a bit of air. After the first time that was it complete lose of pressure, sometimes it will drizzle out sometime a bit of a stream and sometime nothing. Still no leak frm bell housing or master. So I will assume master then? What do you guys think
Old Jun 8, 2013 | 1:07 PM
tragichip's Avatar
Ya it was the master, the spring inside the master broke in 3 different places, so just a heads up for anyone with the same problem, its a quick and about $80 replace
10er
May 11, 2015 9:29 PM
Titan2087
Jul 7, 2010 10:28 PM
pidji
Nov 20, 2008 8:51 AM
