Where is canister purge valve?
I need to replace my canister purge valve on a 1998 cavalier. I have the replacement part but I can't find the part. Can anyone help me locate this?
not sure which engine you have.
most purge valves have a hose that connects to the throttle body...follow the hose to a solenoid with a 2 wire connector. what symptoms are you having that make you think the purge solenoid is faulty? |
Originally Posted by tech2
(Post 446392)
https://cimg6.ibsrv.net/gimg/chevrol...5137d6ea43.jpg
Top view of engine https://cimg7.ibsrv.net/gimg/chevrol...9fd54356e2.jpg Side view of engine https://cimg9.ibsrv.net/gimg/chevrol...bfc66f2c75.jpg The part i need to replace |
should be left of the throttle body and near the tps sensor. can't see it in your pics
if the purge doesn't fix it. I will walk you thru some testing. |
