TH 2000 4R. 1st gear not working.
After fill with transmission oil, because empty of oil and making a sound. Now the transmission doesn't in 1st when running. Is a El Camino 80. What is the tipical problem for this problem? Thanks in advanced. |
Pull the trans pan off and see if there is metal or clutch plate material in it. If so, you have a mechanical problem. If not, you may have a hydraulic problem. Do any of the gears work?
