Cobalt This sporty compact was faced with the difficult job of replacing the popular Cavalier, but whether the base model, or the supercharged SS is chosen, is has made for a great replacement.
Platform: Delta
Also Check out CobaltSS.net
Door Lock Issue
Old Feb 10, 2012 | 10:06 AM
rockonollie2's Avatar
Default Door Lock Issue
I just purchased an 06 Cobalt LS, price was good so we were expecting to encounter some minor issues. We had our mechanic check the engine and electrics and all that is fine.
But our first morning with the car we discovered our first issue. The key won't lock or unlock the driver side door. The key works fine in the passenger door.
Old Feb 10, 2012 | 3:19 PM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> rockonollie2,
Was the vehicle purchased from a Certified Pre-Owned dealer? Did it come with a warranty?
Louis
GM Customer Service
Old Feb 10, 2012 | 6:27 PM
so the key doesn't turn in the cylinder?? or does it turn but not move the lock mechanism?
Old Feb 11, 2012 | 6:59 AM
Unfortunately it was not bought from a GM/Chevy dealer and is not under warranty.
The key does not turn in the cylinder at all. The passenger side works fine.
Old Feb 11, 2012 | 10:36 PM
the lock cylinder may be seized from lack of lubrication and lack of use.
dip the blade of the key in new engine oil and repeatedly put it in and out of the lock cylinder. Do this 4 or 5 times to fully lube the cylinder with oil. Then try to turn the key in the cylinder...wiggling it one way then the other.
refinisher
Jun 12, 2020 12:51 PM
ambiguous216
Jan 17, 2011 12:11 AM
Mastiff
Jul 12, 2010 8:39 PM
davbell22602
Mar 10, 2010 8:36 PM
jim@letjimdoit.com
Jan 25, 2008 2:08 PM
