restrictor plate
i was wondering if anyone knew if the cobalt SS had a restictor plate
its not the supercharged |
RE: restrictor plate
Do you mean an intake restrictor plate? I've taken off 2.4L and 2.2L TBs and intake manifolds and have not seen a restrictor plate of any kind. Not in the exhaust either.
The 2.4 uses a 1-piece plastic intake manifold with a 68 MM TB (base opening measurement - not venturi). The 2.2 uses a 2-piece glued-together intake manifold with a 60 MM TB (base opening measurement - not venturi). The 2.4 intake manifold has larger runners and the TB is centrally located while the 2.2 TB is offset to the drivers side. |
