04' A/C fan problem
04' A/C fan problem
I have a 04 Colorado Z71 2WD. The A/C fan blows on high only. It was intermittent at first but know permanent. When the fan speed is set to 1,2 or 3 with the A/C button depressed the compressor kicks on but fan won't blow. Works fine when fan is set to high (4). Suspect a relay or something. Any suggestions?
RE: 04' A/C fan problem
Hey Guys help is here! If your vehicle is out of warranty, replace your blower resistor. 2004 thru 2008 colorado uses part#15218254 if you have access to A/C Delco dealer use 15-80521. Cost $14.00. It is located at the bottom of your A/C blower motor.
They just replaced the resistor on my 2004 Colorado yesterday. 4th time in 2 years.
My symptoms were different - the fan was spinning, but no air was coming out of the vents.
Replacing the motor blower or the harness
I replaced the motor blower resistor to my 06 Chevy Colorado. One week later the AC is doing the same thing (Blows only on high). Should I replace the motor blower, the harness, or the resistor again. Please help
pdrayton
10
May 5th, 2024 2:27 PM
pdrayton
May 29th, 2013 7:55 PM
SweetEmotion
April 27th, 2012 8:35 PM
Tosha0516
April 2nd, 2010 4:10 PM
