2013 vette blower motor
2013 corvette blower motor does not work
Any suggestions |
Go through the process. Check the fuse first, the relay, and the resistor. The switch could be bad and also a wiring problem.
Relay pin diagram- 2013 vette
Originally Posted by Cjwoody
(Post 343372)
Any suggestions |
They only plug in one way.
Relay install
Originally Posted by oldchevy
(Post 343457)
I am looking for The 4 numbers on the back install diagram for correct orientation to plug the relay back in I can make out a couple like 30 87 etc- they plug in and then can also plug in 180 from that position - maybe it's ok maybe not? |
