Chevrolet Colorado
Platform: GMT 350, GMT 31XX
2013 vette blower motor
Old Aug 31, 2017 | 10:02 PM
Cjwoody's Avatar
Default 2013 vette blower motor
2013 corvette blower motor does not work
Any suggestions
Old Sep 1, 2017 | 7:55 AM
Go through the process. Check the fuse first, the relay, and the resistor. The switch could be bad and also a wiring problem.
Old Sep 2, 2017 | 1:18 PM
Cjwoody's Avatar
Default Relay pin diagram- 2013 vette
Any suggestions
Pulled out a couple relays and need the pin connector diagram to put baxk in correctly
Old Sep 3, 2017 | 12:57 AM
They only plug in one way.
Old Sep 3, 2017 | 10:14 AM
Cjwoody's Avatar
Default Relay install
Hello
I am looking for The 4 numbers on the back install diagram for correct orientation to plug the relay back in I can make out a couple like 30 87 etc- they plug in and then can also plug in 180 from that position - maybe it's ok maybe not?
